Hi Brian, I just noticed that my CWOP upload has not worked since November 22nd when I last updated WD to build 294. I checked the set panel and all seems good there, correct values are in place and the switch is on. I ran croncwop from build 294 in Terminal and no data was transferred. I then ran croncwop in Terminal from my old WD build 24 and that seemed to work ok, results attached.
The new version uses a separate ini file just for cwop
If you click on test send is that created?
I am away on holiday until later tomorrow so can not help more than that
I did not find a .ini file created for CWOP. No rush Brian, enjoy your holiday!
there should be a file called
wdisplayftpcwop.ini
created
(in /Documents/wdisplay/
I tried again, the file did not get created. Also I just realized the PWS.ini file is not created properly, no dot to indicate the file extension.
re the cwop ini file
that tells me you do not have in use the latest update
I will update WD again with a new build number and to fix the pws issue
new build ready
Looks good Brian, thank you. Both cwop and pws working fine now.
Went, to B295… setup Cwop (or so I thought), did a test
I see the ini file for Cwop in /documents/wdisplay
but my station still does’t have data. Not a show stopper by any means
Perhaps I just need to wait for data to collect
Weather Conditions At CW3112***
screenshot of my setup
I don’t see the switch turned on, on the screenshot you provided. Also your Station ID appears to have an extra numeral at the end if I am reading that correctly.
GOOD catch… I just fixed those. Don’t think Cwop updates as frequently. I will keep an eye out
Many thanks
do not have the - in the longitude
When I remove, I get errors (says to ch
When I put it in, and press check, it says OK
all 3 errors attached. I will play around with the format some more
yes, you need to space out with a 0
like you have
