CWOP Identifier
I have recently changed my CWOP identifier from CW2667 to my Amateur Radio call sign…KB2COP. I believe I made all of the correct changes in the CWOP setup, but I can’t seem to upload the changes. I have been uploading under my call sign for three days now and findu shows no activity (except when I tested it under WeatherLink…uploaded o.k.). I have double-checked with Russ Chadwick who advises that everything on his end is setup for my call. Anywhere else I might be able to look/change parameters within Weather-Display?
Thanks, John Schneider
have you ticked, i am not using a cwop call sign?
and what about entering a licensed ham code
( not sure if you need that or not)
i do know others have it working OK with their call sign, maybe they can help out
Yes Brian…I do have “I am not using a CWOP call sign” and I have entered my valid call sign of KB2COP in the appropriate field.
(where it has normaly otherwise a -1 ?
I am new to using my call sign for CWOP…are you saying that I might need a -1 at the end of my call?
no, there is a place to enter you licensed ham call sign, in another place on the setup screen,which by default is -1
I thought the same that perhaps you may have forgotten to tick that box but apparently not. It sounds like it should work. Have you been uploading successfully before with CW2667 before you changed it to your call sign?
You should be able to use the default “Licensed ham aprs validation number” of -1. Your call sign should match what is in the CWOP database.
Did you try stop/exit/restart of WD? Any error messages in the ftp logfile?
Bill,
Yes…I have had success for years with CW2667 and Weather-Display. I cannot find any error messages in the FTP log and yes again…I have stopped and exited the program twice. I even did a PC reboot to no avail. I’m sure this is going to be something simple, but it just isn’t occurring to me yet. As for the CWOP recognizing my amateur radio call sign, I have been running Weatherlink all evening and the data shows up when I do a search for KB2COP.
John
(I really appreciate all of the help)
try a test
and then go to view, ftp log, view full log
and then it will show what is actualy being sent
and post that here
also check you dont have any trailing or leading spaces
the tick for it is ham call sign is just so that wd does not then worry about checking the cw number is formated correctly
but the -1 i thought that you would need to change to your licencse number, but i am no expert
The -1 is almost certainly irrelevant. It’s called the SSID (secondary station ID) and it allows you to transmit your callsign on up to 16 different frequencies at once (blank, plus 1-15 are allowed). With an Internet link it’s not relevant (assuming you’re not also transmitting APRS data via radio) and can quite easily be left as blank.
I think the -1 that was being referred to was the default value in the APRS validation box as opposed to the SSID. If you want your wx observation broadcast on RF from the APRS IS server you fill this in with a validation number. I used the number I got when I registered UIView but I think you can get one from Russ at CWOP(?). Before that I uploaded fine with the default of -1. In any case, John’s observation should still make it without the number although perhaps WD needs either a validation number or the default of -1 so maybe it cannot be empty? Good luck John, I hope you get it working. Follow Brian’s suggestions with regards to the ftp log, maybe it will provide a clue.
Oops! Sorry Chris, I think you and I were talking about the same thing after all. #-o In any case the point is the APRS number of -1 should work.
O.K. detectives…here is a paste of the FTP log. I hopeit contains enough relevent info. to solve this delema.
I am also a bit confused as to the “-1” that everyone is referring to. Where would I place that?
FTPUPD.EXE started at 8:28:01 PM 11/17/05
agenda items to do…
domesodownload
list of files uploaded*
FTPUPD.EXE finished at 8:28:06 PM 11/17/2005
Time taken = 0.02 minutes
Total bytes uploaded = 0 K
Total bytes uploaded for the day = 525 Mb
Total bytes uploaded for the month = 8094 Mb
FTPUPD.EXE started at 8:29:01 PM 11/17/05
agenda items to do…
domesodownload
FTPUPD.EXE finished at 8:29:06 PM 11/17/2005
FTPUPD.EXE started at 8:30:01 PM 11/17/05
agenda items to do…
domesodownload
dowunderground
doanythingweather
dohamweather
do aprs data send
doftpdown
doftpdown2
doftpdownmetarstation
doupload
Files to upload*
Local files: c:\wdisplay\webfiles\dailylogout.html
Local files: c:\wdisplay\webfiles\mesomap.gif
Local files: c:\wdisplay\webfiles\mesomaphot.htm
Local files: c:\wdisplay\webfiles\myweather.htm
Local files: c:\wdisplay\webfiles\myweatherdial.gif
Local files: c:\wdisplay\webfiles\cloudheight.gif
Local files: c:\wdisplay\webfiles\gizmo.gif
Local files: c:\wdisplay\webfiles\conditionscolour.jpg
Local files: c:\wdisplay\webfiles\myweather.gif
Local files: c:\wdisplay\webfiles\dailyhighlowbaroetc.gif
Local files: c:\wdisplay\webfiles\summary.gif
Local files: c:\wdisplay\webfiles\trends.gif
Local files: c:\wdisplay\webfiles\dirplot.gif
Local files: c:\wdisplay\webfiles\dirplot2.gif
Local files: c:\wdisplay\webfiles\curr24hourgraph.gif
Local files: c:\wdisplay\webfiles\curr48hourgraph.gif
Local files: c:\wdisplay\webfiles\curr72hourgraph.gif
Local files: c:\wdisplay\webfiles\energy.gif
Local files: c:\wdisplay\webfiles\realtimegraph.gif
Local files: c:\wdisplay\webfiles\realtimegraph2.gif
Local files: c:\wdisplay\webfiles\forecasticon.gif
Local files: c:\wdisplay\webfiles\forecasticonstation.gif
Local files: c:\wdisplay\webfiles\localweather.gif
Local files: c:\wdisplay\webfiles\weatherbanner.gif
Remote files: dailylogout.html
Remote files: mesomap.gif
Remote files: mesomaphot.htm
Remote files: myweather.htm
Remote files: myweatherdial.gif
Remote files: cloudheight.gif
Remote files: gizmo.gif
Remote files: conditionscolour.jpg
Remote files: myweather.gif
Remote files: dailyhighlowbaroetc.gif
Remote files: summary.gif
Remote files: trends.gif
Remote files: dirplot.gif
Remote files: dirplot2.gif
Remote files: curr24hourgraph.gif
Remote files: curr48hourgraph.gif
Remote files: curr72hourgraph.gif
Remote files: energy.gif
Remote files: realtimegraph.gif
Remote files: realtimegraph2.gif
Remote files: forecasticon.gif
Remote files: forecasticonstation.gif
Remote files: localweather.gif
Remote files: weatherbanner.gif
Thanks for all of the suggestions.
John
Hi John…that -1 is the default in the APRS validation number box (below the TEST button).
http://mywebpages.comcast.net/dshelms/wd_aprs_setup.html
Hmm…in my full ftplog it shows when it connects or tries to connect to the APRS server. Hopefully Brian can offer some more guidance.
you need to click on view full log and post the contents of that after a cwop data send
Sorry Brian…I didn’t completely understand. I think this will be what you described:
Start Time/date:10:03:48 PM 11/17/2005
nyz079.txt
nyz079.txt
Permanent connection selected
Checking for what else to do…
there are 1 more things to do
Aprs data sending now…
APRS Connecting to: newengland.aprs2.net
Aprs connected
sending pass command
user CW---- pass KB2COP vers wx-display 10.30o 31
Sending the aprs data now
APRS data send:
CW---->APRS,TCPIP*:@180303z4056.03N/07252.97W_018/005g010t038r-117p330P01
3b10229h46.WD
Disconnecting from the aprs server now
APRS disconnected
Finshed email agenda
Finished email agenda, no ftp items to do…
Looks like it’s sending your call sign in place of an APRS registration number.
When mine runs it looks like:
APRS Connecting to: aprswest.net
Aprs connected
user KC9DNQ-3 pass ***** vers wx-display 10.30g 4
APRS data send:
KC9DNQ-3>APRS,TCPIP*:@181130z4120.50N/08817.87W_182/010g017t027r000p000
P000b10248h68.WD
Note: I replaced my validation number with ***** for this copy/paste. Do you have KB2COP in the Station ID box and -1 in the Licensed Ham APRS Validation Number box? Good luck.
Alright…I am now going to put my stupidity on display for all to see !!!
I was placing my calll in the APRS validation field as opposed to the CWOP Staion ID field. All is well and I thank everyone for all of your help (now to try and find my way home after work!!!)
John
John…Great to hear you’re up and running now! :smiley:
