CustomTextOut problem
I can’t seem to get my CustomTextOut to work properly again after a rebuild. I am using the current version of WD. I thought that I had the setup done correctly, but it isn’t creating the file. Can someone walk me through the setup process for this again? Many thanks
have not heard from you in a while jeff…
under setup, log file recording, produce a custom text file
then have a file called customtext.txt in the webfiles folder…and then the new file, customtextout.txt is produced in the web files folder
Thanks Brian, I have been lurking - not working!
email me your settings, and the customtext.txt file
(go action, back up registry entry now, then email me the wdisplay.ini file from the folder databackup, or from c:\windows or c:\winnt)
rain: check in the wd dallas 1 wire settings that you dont have ticked to use page 14, maybe?
I’ll have to wait til the weekend. My systems remote and it’ll be easier if I’m there in person. Thanks for the help…
