Custom Tags and Cumulus Software
I need to create an output file that is equivalent to what Cumulus produces as I have another program thta will only accept this format.
I need a text file that looks like this.
Feb 01 2009 12:34
272/010g006t069r010p030P020h61b10150
Format of the file
The first line is the time the file was created in local PC time.
The second line is the wx report. The format is:
272 - wind direction - 272 degrees
010 - wind speed - 10 mph
g006 - wind gust - 6 mph
t069 - temperature - 69 degrees F
r010 - rain in last hour in hundredths of an inch - 0.1 inches
p030 - rain in last 24 hours in hundredths of an inch - 0.3 inches (Cumulus does not supply this value)
P020 - rain since midnight in hundredths of an inch - 0.2 inches
h61 - humidity 61% (00 = 100%)
b10150 - barometric pressure in tenths of a millibar - 1015.0 millibars
How can I have WD create the text file. Would it be to create a cusotm tag file? If so how do I get the custon tag file to create the text file?
Tom
see
setup
create aprs wxnow.txt
That is embarassing! Anway to control how often the file is created?
Tom
its updated every minute
Thanks. I noticed that my Vantage Pro is showing .60 in/hr rain rate. The WXNOW.TXT file is showing r006 which is .06in/hr??
Tom
WD is writing the total rain fallen in the last immediate hour
