Custom Screen – how to display on second monitor when WD starts - SOLVED
Custom Screen
the last screen position of the custom screen is saved when you right mouse click and click on save settings now
in the custom screen
make sure you do that before you restart WD or the PC
should that process work on 37N? I do not have a “save settings now” option when I right click on the custom screen. I get 4 “set…” options and one “type in the tag to use”
I have been able to make it work in this way -
I moved the screen to the other monitor. then I closed the custom screen via “x” in top right corner (not closing WD just the custom screen). then I closed/re-started WD.
I restarted computer to confirm.
