Custom data input to Weather Display
Hi!
I have a smart home with Z-wave, Zigbee and WiFi. I am thinking about buying a Z-wave sensor that gives me lightintensity and UV. Can I somehow get it into Weather-Display? I am using Home Assistant and node-red and can do it either via some file that I write to or via MQTT or similar.
Are there any possibilites?
I mainly want them inside Weather Display to be able to use them for WXSIM and to get all weather related logs in one system.
check out the universal.txt file included with the WD install files
Thanks! Is it possible to only provice the w/m2? Or do I need to supply all values? When its done, how do I set it up to use that solarvalue?
This software is incredible!
Does anyone know if I can input only the solardata via this method somehow?
how do you mean exactly?
do you mean you have WD set to get live data from a weather station
but you want WD to use just the solar data from this method?
Yes, I get weather data from Netatmo and want to get solar data this way.
Isnt it possible to just send solardata this way?
its currently not possible at this stage
its not as easy as waving a magic wand
but I do have it where you can use a weatherflow station with other weather stations and select just to use specific weather data from that (e.g solar)
