Mermaid Inn, Peak District, UK Home Weather Station (ecoLcl version) (weather-watch.com)
My barometer tile is set to display in hPa but the current reading is showing as inHg for some reason. Is that a setting I’ve got wrong?
PS. The station is currently offline due to work on the Starlink system.
No, it’s a standard feature for the casual visitor. If you change units using the °F at the top of the page the readings will be reversed.
I’ve renamed my “Current” box. . .
I added the line below to the bottom of lang_en.txt
|Current|Other Units|
Is that the right/best way to do it?
OK for English, because “Current Sky”, “Current UV Index” and “Current Cloud Base” (if used) are treated as phrases, but all other languages will still say “Current” pressure. I think that’s acceptable. . .
I can live with that…whether foreign visitors to the site can live with it remains to be seen.
