Can somebody please help. On my site the current conditions is always showing as -999 degrees C. Also earthquakes have stopped working.
Many thanks and regards
There have been a few recent posts about earthquakes stalling, e.g. https://discourse2.weather-watch.com/t/stalled-data-for-earthquakes/71835/ You will need to make some changes to get it working again.
Don’t know why your current conditions are giving odd values though.
Hi alienburt,
You are running the 2019 July version of PWS_Dashboard.
That version is 4 years old and unsupported for 3 years.
There are numerous changes impossed by the data-providers.
Darksy closed their business, the free earth-quake provider also.
I used this to see the messages > Derby UK Home Weather Station (wd version)
These are some of the errors caused by using DaerkSky which does not exist anymore.
<br />
<b>Warning</b>: Illegal string offset 'summary' in <b>/home/r11derby/public_html/pwsWD/currentconditionsDS_block.php</b> on line <b>85</b><br />
<br />
<b>Warning</b>: Illegal string offset 'icon' in <b>/home/r11derby/public_html/pwsWD/currentconditionsDS_block.php</b> on line <b>86</b><br />
<br />
<b>Warning</b>: Illegal string offset 'temperature' in <b>/home/r11derby/public_html/pwsWD/currentconditionsDS_block.php</b> on line <b>87</b><br />
<br />
<b>Warning</b>: Illegal string offset 'apparentTemperature' in <b>/home/r11derby/public_html/pwsWD/currentconditionsDS_block.php</b> on line <b>91</b><br />
<br />
<b>Warning</b>: Illegal string offset 'windBearing' in <b>/home/r11derby/public_html/pwsWD/currentconditionsDS_block.php</b> on line <b>102</b><br />
Better use easyweather-setup and choose another provider for the sky conditions 1 hour forecast.
Some of the other 1907 users show the same problem but not all.
So there is a solution possible.
But I think it is better to install the latest version.
The 2012_lts version has full error/problem support for years to come.
Thank you Wim - much appreciated.
Do you have a link to the recommended version please
Regards
Thank you for your help
You have to do a full install!
One can not upgrade from 19.07 to 20.12
After you installed this latest version, there is a script to run and fetch new updates, if there are any.
Cheers WIM. One of the blocks allows me to run my webcam on the site - will I need to modify the appropriate code again when I do the update? regards
Maybe you have, but those blocks are widely used compared to the 1907 times.
Better make an off-line copy of those scripts webcam_c_block.php and webcam_popup.php.
We can use copy paste to adjust the new webcam blocks with your credentials at https://ivideon.com .
Thanks again for your time
