After every update, when i start WD for first time, i have to manually start cronpakbusnew.exe to get data.
After next restart of wd, it will start along with WD.
And after previous update, the nighttime icon isnt shown on the mainscreen
After next restart of wd, it will start along with WD.that is odd...as that should the the same case as when you update
yes strange, i see a screen (cant tell if its the cronpakbusnew screen…) passing by but it disappears very fast…
the problem is then not related to updating WD but to do with when you exit WD
the next update will fix this
…when i start wd directly after the update, i see that screen flying by…
yes
but its not actually related to an update
but the next version of WD will fix it
ok.
do you have an idea why the night time image isnt shown, mentioned in this topic?
I have already replied to other threads about that
do you refer to the Sunshine hours topic? i thought your reply was for user Matrix…?
both
I forgot to mention when closing wd, i have to manually close cronpakbusnew…
Cronpakbusnew is now starting along with wd, but wd doesnt get data, While the cronpakbusnew screen is updating fine. …
nothing has changed to do with how that works
Thats strange, the mainscreen isnt getting data, the data received Light is flashing normally and cronpakbusnew is updating Every second…
In have nothing changed settings wise with latest update
I have to install previous version to get data again…
as you can see in the pic below, since latest update no data is shown:
Partly solved, after full pc restart wd gets data again, strange.
but i still have to start cronpakbusnew after update, second start its fine.
and cronpakbus wont close when closing wd.
the next update will fix the issue of cronpakbus not closing
Still the same issues:
cronpakbusnew wont start along with wd after update (second start of wd cronpakbusnew starts along with wd fine)
cronpakbusnew wont close along with wd (never)
I assume you are closing WD via action, save and exit?
no, by exit, save and exit
sorry, that is what I meant
