Please see attached image. Process is constantly crashing and adding an event log record. Running on Windows server 2022. WD version 10.37S 151.
What is your programerrorlog showing that is in the main WD folder
Not much. One error in 2024.
ERROR: Library not registered System.Win.ComObj at time/date 22:22:5:629 01/02/2020
Above error or program log occured at :22 22 05 01/02/2020
ERROR: Access violation at address 01AE439A in module 'WeatherDisplay.exe'. Read of address 000004FC System.SysUtils at time/date 14:7:17:826 02/14/2020
Above error or program log occured at :14 07 17 02/14/2020
ERROR: Access violation at address 01AE439A in module 'WeatherDisplay.exe'. Read of address 000004FC System.SysUtils at time/date 14:7:17:842 02/14/2020
Cannot create file "C:\wdisplay\WDISPLAY.INI". The process cannot access the file because it is being used by another process
Above error or program log occured at :19 54 17 11/19/2022
Cannot create file "c:\wdisplay\WDISPLAY.INI". The process cannot access the file because it is being used by another process
ERROR: Access violation at address 00137C4A in module 'WeatherDisplay.exe'. Write of address 00000000 System.SysUtils at time/date 21:2:47:504 27/04/2024
Above error or program log occured at :21 02 47 27/04/2024
Now when I open WD, no data will download from the logger. It doesn’t even try.
When I go to control panel then data logger, nothing opens up. I can’t open this module. I re-installed WD. Same result.
Might be worth contacting Brian by email. It’s possible that a Windows update has broken something.
That log suggests the date format has changed when you had a similar error in 2020 it was m/d/y now it’s d/m/y so something has changed, what caused the error in 2020 and what did you do to correct it as it may have happened again.
I take it you have tried old faithful ie reboot with full power off
As Chris has suggested my be best to email Brian
Yes tried the reboot etc. I’ll email Brian.
I am also getting windows desktop manager crashing every couple weeks or so.
Does WD run on server 2022??
If my memory is correct then Windows Server 2022 is based on Windows 10 so I suspect WD would run on it.
Hmmm
for Windows XP (with latest updates) VISTA/W7/8/8.1/10/11…
Might need an email to Brian?
Yes, I have been running on that OS for some time.
