WD has the ability to create html files from txt files, changing them on the webserver. But if I want to do it, not on the webserver, but on the webfiles folder, what’s the best way? For example, I want to convert a waplocal.txt file in a wap.html…
Cheers
H
ah, i would have to put in a special file conversion, with the ability to set the new filename in the webfiles folder, like for that particular file
Hi, Brian
So, when you find a little time…
Thnaks again
Cheers
H
Lol, I forgot to say please!
You can do it with custom HTML pages.
Just use the PRE /PRE html codes.
Here’s an example of both IFRAME and imported text…
http://members.cox.net/carterlakeweather/wx4.html
The warnings are IFRAME from the NWS and the haz outlook is a pulled text document embedded using the metar text custom tag.
Yes, thanks, I was thinking about that, and then I can convert a wx.html file to the file name I want in WD file conversion, right?
Thanks a lot
My best regards
H
