How can I add additional amounts of precipitation resulting from snowmelt in rain_c_block.php where the sources are given by ecowit, ambient, weatherflow, netatmo stations. Is there a script similar to PWS_snow.php, to correct the precipitation data.
Marian
One can modify the history to add extra amounts of rain.
That is the only way to modify the data as the PWS_Dashboard uses the data from a weather-program or weather-station.
The snow amount/height is an extra sensor which most weather-programs do not support. That value is accepted as-is and displayed as a separate value on the dashboard.
I do not see how we can add melting snow to todays rain value.
Normally when it melts, the rain sensor should measure it.
But I am living in an area with minimal snow-fall which also melts in a few days.
