Interestingly, I haven’t had the freezing icon problem up through b266 but when I installed the latest version, b281, on Saturday I now do. Also, the screen gif (animated) no longer updates. No errors in the event log.
Roger
Roger
when you get the control panel icon problem then there will be errors
you can also check the programerrorlog.txt file
I have not changed the main screen animated gif creation, so that is strange that is not working for you
(how exactly do you mean by its not working though?)
I have done more updates to build 281, so make sure to use the latest update
Yes, lots of errors, all since switch to b281. I’ll send them tonight. Main screen animation is no longer saving except on WD startup, which I have set to save and upload every 5 minutes. This was working in b266. I can try canceling gif. and see if the icons start to work again.
Roger
Here’s the last few entries from programerrorlog.txt:
Failed to save main screen animation Access violation at address 004D8574 in module ‘weatherdisplay.exe’. Read of address 30303040
Above error or program log occured at :5:30 pm 07/29/15
Failed to save main screen animation Access violation at address 004D8574 in module ‘weatherdisplay.exe’. Read of address 37324352
Above error or program log occured at :5:35 pm 07/29/15
ERROR: Access violation at address 00409E4A in module ‘weatherdisplay.exe’. Read of address 37324352 System.SysUtils System.SysUtils at time/date 5:38 pm 07/29/15
Above error or program log occured at :5:38 pm 07/29/15
ERROR: Canvas does not allow drawing System.Classes System.Classes at time/date 5:38 pm 07/29/15
ERROR: Access violation at address 7741308E in module ‘ntdll.dll’. Write of address 00000014 System.SysUtils System.SysUtils at time/date 5:38 pm 07/29/15
I’ll stop the animation and see if that helps.
Roger
I stopped animation and screen gif now is created and uploaded but icons freeze in a matter of hours.
Roger
I just noticed tonight that probably starting when I changed the screen animation gif to a plain gif testtags.php stopped being created. I just switched back to b266. (on Vista) I can try the latest zip this weekend when I have more time.
Roger
Brian - latest 281 debug build - 3 days
Access violation at address 004D8574 in module ‘weatherdisplay.exe’. Read of address 4F4C8D83
Above error or program log occured at :13:00 07/30/15
Access violation at address 00409E4A in module ‘weatherdisplay.exe’. Read of address 4F4C8D83
Access violation at address 018FBD2A in module ‘weatherdisplay.exe’. Read of address 000003B4
Current warmest day value (oC) 24.3 18:00:00 07/30/15
Above error or program log occured at :18:00 07/30/15
Resetting coldest night values 18:00:31 July/30/2015
Resetting coldest night values 18:01:31 July/30/2015
Above error or program log occured at :18:01 07/30/15
ERROR: Access violation at address 004D8574 in module ‘weatherdisplay.exe’. Read of address 4F4C8D83 System.SysUtils System.SysUtils at time/date 19:39 07/30/15
Above error or program log occured at :19:39 07/30/15
The entire content of the debug from Control panel is in the attached text file.
Craig
debug.txt (5.11 KB)
I am slowly narrowing it down…I am working on it
oddly
I dont get the errors on my development pc, running with the same settings as my (low speced) weather pc
I think I might have cracked it
will know in a few hours
success
you should find with build .zip update, 282 is OK now for this particular problem
(was a very obscure problem and was actually to do with the way the new compiler works…i.e code that worked OK before was not working OK Now
and I was going around in circles! )
thanks everyone affected for their patience and understanding and helping me track it down
Brian
Thank you - downloading and installing now.
Craig
D/L and installed. All good so far!!
Build 282 has been running for a little over 3 hours. Getting some errors and the buttons in Custom Internet and File Creation are not responsing. The programerror log can be opened as well as all the icons in the control panel screen. That is real progress.
The tag %weatherdiscription% was updating but stopped after about an hour. The advanced graphs were also updating but have also stopped. Pressing the advanced graphs button on the view screen kicks me out of the view screen.
Looks like a bunch of access violations…
Access violation at address 004D84E8 in module ‘weatherdisplay.exe’. Read of address 4F4C0656
error with summary save Access violation at address 004D84E8 in module ‘weatherdisplay.exe’. Read of address 4F4C0656
ERROR: Access violation at address 004D84E8 in module ‘weatherdisplay.exe’. Read of address 4F4C0656 System.SysUtils at time/date 21:35:53:714 07/31/2015
ERROR: Access violation at address 004D84E8 in module ‘weatherdisplay.exe’. Read of address 4F4C0656 System.SysUtils at time/date 21:36:10:473 07/31/2015
ERROR: Access violation at address 004D84E8 in module ‘weatherdisplay.exe’. Read of address 4F4C0656 System.SysUtils at time/date 22:1:17:827 07/31/2015
error with new chartsAccess violation at address 004D84E8 in module ‘weatherdisplay.exe’. Read of address 4F4C0656
Getting better.
Gus
i had not changed all the code to the new way that is needed
by the compiler e.g in the customize internet and file creation setup.but i will do that
Files seem to be being created and uploaded although times seem a bit odd. Testtags.php is now working but uploads are behind schedule…maybe every 12 minutes not the 5 minutes it should be. I haven’t had a chance to investigate.
Icons were frozen this morning and quite a few errors in log.
Thanks!!
Roger
there is a new update to build 283 to change over all the remaining code to this new way, that I had missed
I’m still having issues with icons freezing with latest zip on Vista. I’ve been very busy at work so I’ve had little time to investigate.
Roger
Brian
Welcome back. 282 has been very stable - am downloading and installing 284
Talk to you in a week…
Craig
I’ve been running 282 for a week and no errors.
Tom
I have found a couple more places in the code that would cause the problem too
in build 285
