Hi, yes Windows will ask for confirmation to run any new version so just untick the “always ask” box for each program when it appears and Windows will stop asking.
I am seeing WD kind of hang and say it is not responding. Then returns to normal operation.
Another question is why when you open CWOP in Publication you hover over any of the “click here to go to …” a blue circle keeps spinning next to the mouse arrow? I haven’t seen that in any of the others.
Is the Control Panel issue is being caused by the Custom Client Raw File (Steel Gauges)?
Is this also causing Weather Display to once and a while hang or say at the top “Weather Display - Ver 10.377R281- Not Responding” and then after a bit, return to normal operation? (Topic = WD hanging randomly)
actaully the majority of users actually do not have the problems reported in this (or similar) threads
note that problems with using setups from the control panel is a symptom of errors occuring in WD and increasing memory use
(a restart of WD will fix those issues)
since I do get the errors on my own weather pc, I have now managed to set up remote debugging, i.e so I can run WD on that pc via the compiler
so I am hoping I can track down the error this way
hopefully…
hi,
no need for others to volunteer re remote debugging as I get the error on my own (low spec) weather pc,
so I am running it remotely on that, through the compiler,
to hopefully narrow down where the problem is more
I just hit 14 days with no errors on b281. I’m in the midst of doing 15 Windows updates and they I’ll reboot and see if I can stay “error free”. I won’t be upgrading to the latest 281 just yet, I’ll stick with this winner for now.
jp
