also make sure you have WeatherD.exe set to run as administrator
Yes
graphdata.inf
graphdata2.inf
graphdata22.inf
graphdata3.inf
graphdata4.inf et graphdata5.inf
Yes (No data inside)
do you have those data files in your data files folder?
(and what is the create/modifed time on them?)
No
-----The value in the 1-wire program is working correctly, but the graph in WD is not recording it.
Error from time to time.
Signature du probl
graphdata.inf
graphdata2.inf
graphdata22.inf
graphdata3.inf
graphdata4.inf and graphdata5.inf (for lightning counts)
does C you cut those dated files in your dated files folder? Yes in real-time, No data inside
(and what is the create/modifed time ONE them?) No
Serge
are those graph data files being updated?
(i.e is the modified date/time on those files changing?)
also, any errors under view, program event log, in WD?
(Sorry for my, English, it is about a translator)
My procedure!
A)
I destroyed the repertory (datafiles) then I have famous (datafiles) inside with nothing.
B)
Then I published wdisplay.ini and I added the lines manually the lines that Weather Display to refuse to keep in memory during the basic adjustments.
Following lines: webdate=usa in webdate=metric and webrain=inches in webrain=mm
That does not explain why it was impossible to change the selection in WD itself ?
C)
Then I completely started again the computer and since that functions with correct dates, and the graphs start to work.
Thank you Brian to have announced me information about the not horodat
maybe the files were set to read only (write protected) or similar
