in place of the two you are using and for Temp I am using:
tempGauge
and you are using:
temp
Look at the same .pdf file that Julian referred to and for each value that WDL can display it will show you your different options for display for that value…
I wish i can get remote access to the server to view the .pdf however there is a problem and i cant get hold of it last thing guys… whats the different command to change the image of the rain/night/could insticon??
I can’t answer that for you. Softvark probably could answer that for you. I thought I seen something like this in the forums but I could be wrong. I will do some more research to see if you can do that.
1 just determines whether WDL uses the icon values as sent from WD or whether it uses the current conditions/forecast text as well. You can ignore this unless you’re having problems with keywords triggering incorrect icons.
i went through the last part of the icons, and i saw the info on them…
“The following icons are displayed in Weather Display Live. Which icon is displayed
depends upon whether you have sync icons enabled within Weather Display and/or
the presence of keywords found in the current conditions text.”
Does this come automatically synchronized? or you will have to set it up??
