Configuring WD Graphs
Hi All, I have been having a recent thing happen with my temp graph on the WD page. At times the plot will indicate some extremely high readings like 3715 F for a period of hours and return to normal. The logfiles appear to be normal and the left hand pane always displays the correct temperature. Also, I don
that will happen when a value is going out of range
so, in the graph setup, try changing the settings there
i.e like use the lift/lower temperature scale buttons…for starters try that
Brian,
I went into graph setup and lowered the scale as you suggested, and it corrected my display. It seems that the recent low night temps were causing this and I feel rather dumb for not figuring this out on my own. :oops: Thanks a ton! :lol:
Jeff
