Hello,
Is it possible to add the following for each month:
Min temperature
Max temperature
in which is then used in the reports.
Example of climare records here http://www.weatherzone.com.au/climate/station.jsp?lt=site&lc=31066
thanks
Hello,
Min temperature
Max temperature
thanks
you can enter a long term average temperature now to use as a comparison with your data
but I have not made it so that you can add max/min
its possible I could
WD does use your own data to work out differences from averages in the detailed climate report
the more data you build up, the more accurate that will become
He has 10 years of data - more than most if not all other users!!
September max temperatures have been below the Mareeba average of 28.2c ( except for one day) and it feels cool as well.
In tropical north Queensland its been the longest winter i’ve seen (started on May 12th)
