After ten years of running WD I’ve moved locations, hard drive died… I’ve had fun!!.
To the matter at hand, sometime in the past weeks I’ve stopped clientrawhour.txt and clientrawdaily.txt from being generated ( clientraw.txt still OK ). I use these files to generate server side graphs (new site broadband bandwith poor). I have the folder set in a directory next to local webfiles on a data drive (F:)…
Can some one please put me on the right track (before I remove what’s left of my hair)…
so you have selected the clientraw directory as needed in the webfiles/web page setup, real time ftp setup?
try then restarting WD
also which version/build of WD?
Possibly a couple of hints…
I can’t get “advanced Internet setup” to override even the clientraw.txt creation times (would like to be every minute or so… not normal update time)…
I set up WXNOW.TXT (same directory) for CWOP all happening OK, 1 min update etc.
what is the barometer reading in WD showing?
also make sure to have the switch on in the webfiles/web page setup, real time ftp setup
but if no ftp needed, then tick that option
also make sure the main internet switch is on in the ftp/inernet setup, connections setup
