is it possible to have a force close and reopen option for this, as i have had some instances after a socket error the program gets in a knot and will not right itself and no data is uploaded for the flash and svg. this seems to continue till i manually shut the clientrawftp down and restart it
which is ok while i am around but in a few weeks i will not be able to do this for a couple of weeks and a pc reboot every 3 to 6 hours seems a bit over the top to get the clientrawftp to close and restart every 3 to 6 hours
i.e. similar to pc reboot setup but just does clientrawftp only
it should do that…already…if there are so many errors in a row…
it does for me.
but maybe there is an error code I am not checking for,…
i.e let me know what the exact error code is (copy/paste)
from a previous log i saved the error code that causes my problem is 10057
is this on your list
how many errors before it should restart
does the logout login restart the program if so it does not work with the above error
this error seems to not allow a automatic restart to take place
will check codes next time it happens
maybe i could add option to have the logout/login actualy restart the program…
(does restarting the problem acrtualy fix it?)
(as that error is a cant connect error, i.e there is no route to the host, i.e the internet connection has been lost)
yes restarting usually sorts it
i have known this error last at least half a day and during this time most of my normal uploads have worked i check it from work.
so a temp connection lose may have caused the initial problem but it seems to be unable to reconnect without restarting the clientrawftp
i have my logout/login set at 30 min if a link to restart the program is possible that would be great
i have noticed sometimes at main upload time that the clientrawftp icon in system tray starts on right of main ftp icon then its on the left
you will have to ask bill gates why that is
i will add this option for you today
but have to go to the farm now (the sharemilker has put his back out)
try a new 10.13y beta
and then there is an option to tick to restart instead of relogin, in the real time client raw ftp setup
ok Brian downloaded latest 13y earlier this evening and have ticked new option and will monitor it and let you know
Thanks for your Help
...i have my logout/login set at 30 min ...I found a time of 5 min works best for me. 10 and 30 min logout/login resulted in the errors similar to the ones you were having.
