Clientrawextra keeps rolling an old forecast
The last few days clientrawextra.txt keeps getting the same wrong forecast
i deleted but still the new one has the same wrong forecast
Any ideas
clientrawextra.txt (3.2 KB)
clientrawextra forecast is a symptom of the forecast not being acquired correctly elsewhere in WD. Check Control Panel ->FTP/Internet setup-> NOAA Forecast download. I saw something where they changed some zone codes recently.
Good luck
Jim
Hi Jim
Thanks for the reply. I dont use NOAA forecast download at all.
Should be somewhere else
i have another station to another location and i am getting the same wrong forecast
A link to your site and a clue about where the forecast is supposed to come from would be of assistance to provide some help.
Jim
http://www.hydraweather.gr
http://www.reaweather.gr
i have no idea the rolling forecast on top were it comes from ?
Nikolas
what type of weather station do you have?
Forecast at the top looks like a forecast from your weather station or WD
davis vantage pro plus
and i use virtual IP , WD and weatherlink
I know nothing about Davis kit, but:
  1. Clientrawextra.txt #531 is supposed to be “Davis VP forecast text”, according to clientrawdescription.txt;
  2. Ken’s parser says it is “Weather Display (or Davis) Forecast”; and
  3. Wim’s parser says it is " forecast weather display (or davis)".
So is your VP console showing the right forecast? Have you updated WD lately?
Might be worth exploring whether forecast is turned on in WD – I would have thought it was automagic if you selected Davis kit, but what do I know?
i ll try and i let you know
Nikolas
it start working again but i didn’t make any change
