Clientrawextra has data in the wrong place
I noticed today that my clientrawextra has data misplaced. The barometer data at offset 574 and 575 has zero in it and the corresponding label data at offset 578 and 579 has the actual barometer readings instead of a time stamp. It seems to be the data at 578 and 579 is what is wrong and is messing up all my 24 hour graphs. The data is not corrected when the clientrawextra is updated. How can I correct the data in WD to make this right? I’ve tried converting my Jan log file to a data file and recreated my 31 days graph data afterwards.
I don’t know how you correct it, but it happens to me occasionally as well - I’m sure I’ve posted about it before. As you say, it messes up the wxgraphs but usually corrects itself after 24 hours.
I just had a thought and I closed WD and started it again and it rebuilds all the clientraw set of files on start up. Now my graphs are OK so I guess doing the log file convert etc needs a restart to get the data picked up correctly.
Would be interesting to see if restarting WD without the log file conversion would work. . .
Might try it next time clientrawextra plays up, although I hate restarting WD because I lose so much data.
Yes, it does! So you only need to restart WD to rebuild clientrawextra.
