Clientrawextra field 578 (solved)
Field 578 in the clientrawextra file in build 78 is a barometric pressure not a time stamp as it should be. It can be seen here:
http://g1gsw.dyndns.org/weather/wxjpgraphs.php
I checked it with the TNET parser to see what the problem was.
Colin
Field 578 isn’t the problem.
Something isn’t right from around field 491, from what I can make out.
What’s your reset time in WD, midnight or 0900?
Also, do you have solar & UV sensors as you’re reporting solar readings from 01:00 to 08:00 and then nothing until 20:00 so it’s indicating night time in Wales is during the day. 8O
I would check your PC/server date/time settings and also check you have the correct latitude & longitude under Control Panel > Solar/Lunar & Coordinates.
Thanks again for the reply. I do have solar and UV sensors it is one of the new WH3081 systems bought to replace my old failed WH2081. My server reports the correct data and time as you see:
Tue Sep 20 12:58:37 BST 2011
The time I checked it and my Windows system is also correct. The server time zone is set to Europe London as is the windows box running WD. I had noticed the odd times for the UV / Solar but couldn’t pin it down as it reports everything correctly in WD itself.
Colin
Hmm I have restarted WD and the problem appears to have gone away for the time being, very odd.
Lets hope it stays that way. :smiley:
