After upgrading to the latest Mac version of WD, I noticed my clientraw updates / uploads are failing after about one hour. Quitting WD and restarting gets the updates / uploads working again.
When the client upoads are starting to fail the ftp logs show:
FTP real vers 1.4 15:25:23
logging on to 72.167.232.152
login OK to 72.167.232.152
Change directory Ok to /wx
Result 250 OK. Current directory is /wx
uploaded /Library/Application Support/wdisplay/webfilesclientraw.txt OK
uploaded /Library/Application Support/wdisplay/webfilesclientrawhour.txt failed
uploaded /Library/Application Support/wdisplay/webfilesclientrawextra.txt OK
uploaded /Library/Application Support/wdisplay/webfilesclientrawdaily.txt failed
Logging off
Any ideas what would cause the clientraw files to update / upload normally and then fail after a short period of time. It can’t be a permissions or password
problem or the update /uploads would always fail.
When the updates and uploads of the clientraw files are working normally, the ftp logs shows:
Client raw FTP Upload 15:50:45 15-5-09
Port to use 21
Passive mode on
FTP real vers 1.4 15:50:45
uploaded /Library/Application Support/wdisplay/webfilesclientrawhour.txt OK
uploaded /Library/Application Support/wdisplay/webfilesclientrawdaily.txt OK
Logging off
