Clientraw description
my clientraw right now says Overcast_and_gloomy/Light Rain
On the map at Northwest Weather Network - Home My Icon allways says DRY Dry
They take my clientraw file to get that icon, but it doesn change. Is there somthing in WD that can fix that? Ive tried the METAR but that doesnt work either. Any thoughts?
‘Dry’ is the placeholder icon for ‘not raining’ when WD is not set to use METAR and/or Solar for conditions.
You’ll need to setup the Summary Image
http://www.weather-watch.com/wiki/index.php/Summary_image/weather_icons_setup
and the Metar to use
http://www.weather-watch.com/wiki/index.php/Getting_Weather_Reports_and_Metar_Data
And if you have a Solar Sensor, do the setup for it also
http://www.weather-watch.com/wiki/index.php/Forecasts_and_Icons
More info
http://discourse.weather-watch.com/p/233510
Hope this helps…
Ken
yes,if you have a solar sensor in use, then make sure you tick, update the icon from the solar , in the solar setup, description
thanks for the info. I should have my solar sensor up and going tomorrow. So i’ll just see how that works first.
