I am seeing up a station for a community on a island just off my coast line. I downloaded the console 64 version for Linux.
I set it up and did the config etc. But it runs and says it cannot find clientraw.txt to upload
{"code":0,"msg":"success","time":"1672145041","data":{"outdoor":{"temperature":{"time":"1672144997","unit":"ºF","value":"-40.0"},"feels_like":{"time":"1672144997","unit":"ºF","value":"-40.0"},"dew_point":{"time":"1672144997","unit":"ºF","value":"-40.0"},"humidity":{"time":"1672144997","unit":"%","value":"10"}},"indoor":{"temperature":{"time":"1672144997","unit":"ºF","value":"69.1"},"humidity":{"time":"1672144997","unit":"%","value":"62"}},"pressure":{"relative":{"time":"1672144997","unit":"inHg","value":"29.57"},"absolute":{"time":"1672144997","unit":"inHg","value":"29.57"}},"temp_and_humidity_ch1":{"temperature":{"time":"1672144997","unit":"ºF","value":"48.4"},"humidity":{"time":"1672144997","unit":"%","value":"84"}},"battery":{"outdoor_t_rh_sensor":{"time":"1672144997","unit":"","value":"0"},"temp_humidity_sensor_ch1":{"time":"1672144997","unit":"","value":"0"}}}}
Starting cronftpreal
updating records to ini file
FTP Real vers 2.2
Time between upload 30 seconds
Client raw remote name clientraw.txt
Port to use 21
FTP to
login OK to
changing to /webspace/httpdocs/inishturk.eu
Could not find the file clientraw.txt
I realise the ecowitt data is wrong as there is no station yet attached, waiting on Ecowitt to post.
I followed the readme.txt and run it as. ./consolewd
I do have another WD running on the same pc with no issues
The additional files are created on.
-rw-r--r-- 1 inishturk inishturk 2722 Dec 27 12:51 clientrawextra.txt
-rw-r--r-- 1 inishturk inishturk 2476 Dec 27 12:51 clientrawhour.txt
I am at a loss now
