Clearing all data, but preserving settings
Should be an easy one. Is there a log file that i can delete that has all the stats from which the graphs, record high/lows, rain data… etc are stored?
I want to clear EVERYTHING that has been logged so far and start fresh, but with all my settings (mainly just the ftpupload settings) preserved.
Cheers.
bump?
I really am not sure if you could just remove log files without causing other issues myself…
You can setup a new WD using this FAQ but it would be from scratch for everything…
delete the logfiles folder, webfiles folder, datafiles folder and the wdisplay.ini settings file, from where WD installed
(when wd is not running)
you will need to reset up the weather station type, units, etc, but your internet setings will be intact, as they are stored in the registry
