Clean Install / Reset of Weather Display?
Haven’t been able to find directions for this in the FAQ or on the forums…
My Weather Display install has been behaving pretty erratically lately. For example, the Yesterday’s Rain has been stuck on the same number and is not changing. There are some other oddities as well. This installation goes back to 2006 or earlier…it’s moved across 3-4 different PCs over the years and I think it’s time to archive all the old data and just start fresh.
How do I do ‘factory reset’ of Weather Display without losing the registration / license? Or should I just archive, wipe it out and contact Brian for a new registration code?
you could try
exit WD
then delete the wdisplay.ini file
(back that up first)
then run regedit.exe
then search for wdisplayftp.ini
in the registry
and delete that
then restart WD
and it should start up like brand new, no settings
Closed - Over 6 months since last post
