I noticed tonight that the YoWindow on my yrno page was totally blank - just a white space. I clicked around on some other folks’ website and everyone else I checked was having the same problem.
Did some digging and I found the problem. It appears that they changed the path to the Flash file.
In the yr_xml.php, I changed the two references of this:
http://repkasoft.com/wimo/hpPal/hpPal.swf
to this
http://swf.yowindow.com/wimo/hpPal/hpPal.swf
And that got it working again. In my file that was on line 78 and 79 but yours may be a few lines off from there depending on how many cities you configured.
Thanks for the heads up on this. I couldn’t find the amended line in my copy of the yr_xml.php file but I did find them in my wxyrforcast.php file near the top of the file, changed them there and uploaded and all seems ok now http://www.weybourneweather.co.uk/wxyrforcast.php. Thanks again
Phil
Greeting!
Similar problem here a while back.
I was using I.E.,
but under a different browser, i.e. google chrome, everything worked fine.
Try that, see what happens.
Good Luck
I know Brian but I prefer not to open two post for the same topic.
About the issue…yes, yowindow uploads correctly but i don’t see the weather data on my yowindow widget
I’ve tried ie and ff browsers.
Hi Jim,
I had already tried but without success!
I’ve just edited… but it always showing “No weather” http://www.meteocarmignano.it/wxysforecast.php
That file exists (yowindow-xml.php) …i think it’s a bashewa’s version…i’ve attached it.
Scrolling forward is the forecast which is working, but Alessandro is missing the current weather.
Alessandro, why don’t you go back to yowindow.com and make a brand new widget? It will only take a few minutes. Review the instructions make sure you have placed the crossdomain file in your root folder.
I’ve just tried without success!
Maybe, i found the issue…at this moment my nearby metar doesn’t show any text (f.e. Clear, Partly cloudy ecc.).
I don’t know if it’s a metar problem or WD problem.
However, this problem may cause the “no weather” in LIVE weather condictions (the issue is only in LIVE mode) for this code:
$incCloudTag = false; // if true we decide else let Yowindow decide cloud
// formation from METAR or WD icon (overrides $incWDiconTag if true).
$incWDiconTag = true; // if true let Yowindow decide cloud formation from WD icon.
// (if this is required then $incCloudTag must be false).
Thanks for trying the new installation, but I see it’s not working yet. Everything looks good to me and I see that you do have a crossdomain.xml file in your root folder. It is a different version than the one that they show on their site http://yowindow.com/widget_and_pws.php so maybe try that new one?
