Changing to OpenWeather Issue
I am trying to change over to OpenWeather for the current sky conditions, however I can’t seem to get it to work. I have signed up with OpenWeather and I have an API key (it’s the free version so I assume it is the right one). I have put that in the Easyweather setup and selected to use OpenWeatherMap, but it does not seem to work.
Here is a link to my site,
Any help with this would be much appreciated.
Neil
See https://discourse2.weather-watch.com/t/darksky-replacement-errors-problems-solutions/73549
There is also an updated script at PWS_Dashboard 2012_lts updates (pwsdashboard.com)
Hi Neil,
Yoiu can not use the free key.
As @bitsostring pointed to → previous post
You need to make sure that you have a “paid” ALL-IN-ONE API-key
Only the One Call 3.0 option loads the OWM → DarkSky replacement file.
Previously there was a free 2.5 version, but that is discontinued.
See attached screenshot.
You can set a limit so that you only use the 1000 free calls to the API.
That way you are charged every day with a zero amount.
Thanks, I have it working now.
