Changing temp font color to red when non-frost and blue when frost?
This temp, in the main ajax dashboard:
This is the code that part use:
<span class="ajax" id="ajaxtemp" style="font-size:28px">
<?php echo strip_units($temperature) . $uomTemp; ?>
</span>
Would it be possible to add a “if” function or something here?
Like if temp is > 0.0 then red font, and < 0.0 blue font?
Best Regards,
Martin
Hi Martin
write after
// — end of settings -------------------
the code
if ($temperature > 0) {
$colortemp = “#FF0000”;
if ($temperature < 0) {
$colortemp = “#0000FF”;
and add the code
before
<?php echo strip_units($temperature) . $uomTemp; ?> and add
regards
Panos
Hi Panos!
That works great, thank you!
Only 1 problem though, this code needs to go into the AjaxWDwx.js too, because when the AJAX script kicks in the temperature color reverts back to black.
This is the code in that file which needs to be changed:
temp = convertTemp(clientraw[4]);
set_ajax_obs("ajaxtemp", temp.toFixed(1) + uomTemp);
I am going to try to figure it out myself, but I think this is Java code, right? So it needs to be different from the previous code.
Best Regards,
Martin
Its showing Red to me even after the ajax has done its bit :wink:
Bashy, that’s probably because the AJAX didn’t update properly. I’m currently testing the code,
so sometimes the code isn’t working and the red font stays because the AJAX doesn’t update
when it’s not working.
This is what the code looks like now:
if (temp >= 0.0) {
   ajaxtemp.style.color = nofrostcolor;
} else {
   ajaxtemp.style.color = frostcolor;
Thing is, the flashcolor parameter is overriding the color… Need to get some help on this, this is basically as far as I can go on my own. :lol:
Best Regards,
Martin
Ah, ok m8, hope ya get it sussed :slight_smile:
Hi Martin,
What you want is doable, but it will require a bit of code change to prevent interference and reset by the ‘green flash’ mechanism.
The existing functions in ajaxWDwx.js as
function reset_ajax_color( usecolor ) {
// reset all the <span class="ajax"...> styles to have no color override
      var elements = get_ajax_tags();
	  var numelements = elements.length;
	  for (var index=0;index!=numelements;index++) {
         var element = elements[index];
	     element.style.color=usecolor;
function set_ajax_obs( name, value ) {
// store away the current value in both the doc and the span as lastobs="value"
// change color if value != lastobs
		var element = document.getElementById(name);
		if (! element ) { return; } // V1.04 -- don't set if missing the <span id=name> tag
		var lastobs = element.getAttribute("lastobs");
		element.setAttribute("lastobs",value);
		if (value != unescape(lastobs)) {
          element.style.color=flashcolor;
		  if ( doTooltip ) { element.setAttribute("title",'AJAX tag '+name); }
		  element.innerHTML =  value; // moved inside to fix flashing issue (Jim at jcweather.us)
could be amended to add a new function
function set_ajax_obsNF( name, value ) {
// no color change
//          element.style.color=flashcolor;
then change the calc for bigtemp to be
var element = document.getElementById("ajaxtemp");
if (temp >= 0.0) {
   set_ajax_obsNF("ajaxtemp", temp.toFixed(1) + uomTemp);
   if(element) {element.style.color = nofrostcolor;}
} else {
   if(element) {element.style.color = frostcolor;}
Then change the
<span class="ajax" id="ajaxtemp">
to be
<span class="ajaxNF" id="ajaxtemp">
so the reset_ajax_color() function won’t find and change the color to ‘’ (nil).
Hope this helps…
Ken
Ken,
Works perfectly, as usual!
It was something like that I’d imagine needed to be done, but the problem was figuring out how to accomplish that.
Thanks you so much Ken, and I wish you a happy birthday!
You can check the “reborn” bigtemp here: http://www.berdalweather.net/index.php
Best Regards,
Martin
SWEET!!!
You’re very welcome, Martin! Thanks for the kind wishes!
I don’t envy you the outside temp (you’re at -8C at 22:00) We’re at +8C for our overnight low :slight_smile:
Ken
Well, the clouds are coming closer in a few hours and the forecasts says some snow in the night and tomorrow. It will be the first real snow at my altitude, the peaks around here are already white. :slight_smile:
+8C for overnight low is higher than many of the overnight lows we had here in July. :lol:
Best Regards,
Martin
Hi Ken,
Are all of these changes in ajaxWDwx.js???
8O 8O
John
