I wonder if it is possible to change the max temperature by hand. now everything is working only the max temp is on the old date and not on the new record date for this year.
See WU data arrays Update Script ** Closed ** for graphs.
Script _wu_upd.php should already be on your server.
Otherwise, one can always update the history file if it has an error-value in it: => pwsWD/PWS_hist_update.php?pw=12345
Replace 12345 with your easyweather pw.
thnx this will do the job
