Change in Default Status for Raw Meta
Raw Data appears in your HTML web page for others
I think the setting for this option in WD should be changed to default to OFF.
The code it generates is not a valid HTML Meta format. Many users have it on and don’t know what it is, or have any use for it. I’m not sure what web applications are actually looking for this type of info, but if they are still in use, they should change their behavior to use valid Meta statements instead.
The Meta format standard has been around for a long time and is used by many many other webapps correctly.
The current default results in an invalid web page which can and does effect how the web contents are displayed in various browsers. A change in default would most likely be unnoticed by most that have it on other than find that some of their pages might display properly now.
It can currently be changed by:
Setup, Advanced/Misc Settings, Program TAB Untick the "Raw Data appears in your HTML web page for others" Press OK to save the settings.
it is off by default
has been that way for some months now
but the first time you go to the misc setup it gets turned on by default
i will change that
