Ceramic leaf wet sensor
I am hoping to make some Ceramic leaf wet sensor for my 1 wire setup
On the surface will be a silver conducting material which will be also embedded in the ceramic
I think it could work with other weather station’s
If you have a wet leaf sensor could you please take a ohm’s reading and the type of station
You use
Thank you
Mick
I will try to remember in the morning Mick, mines a Davis but I have separated the lower section of the track, it’s not a lot mind but it wasn’t getting any heat (for the RD side of things) so I cut the tracks, just letting you know in case it affects the reading at all.
Do i just stick the needle points on the 2 tracks to get the reading?
Hi Mick, my Davis reads around 1.700 ohms
