Cellphone/Mobile Scripts (XHTML Mobile 2.3 Certified)!
Ok, tried the new page, renamed to php.
I still get an error, this time it says “line 62” instead of “line 61”.
See attached…
hmm this is starting to push my php also… might be another file that is causing this… ill have to poke around
ok attached is all the files that appeared to have changed… i think i must have changed some files on the server and never updated my local copy etc… Hopefully this will fix it… most of these are cosmetic but the nws stuff a lot of that stuff is deep php stuff so hopefully that fixes your error…
i most certainly need to update the zip on the first page but want to try to fix your problem first.
cell updates more.zip (102 KB)
I updated all the files that you worked on, and still the same error
on “/cell-advisories.php”.
Thanks for all your work and sorry I am no help to you!
Could it be I need to delete something in the “cache” file? (Just a thought, just trying all avenues)
On a positive note, the new files did fix the UV problem I was having after dark.
Thank you !!
try these updates… i finally had a weather service advisory for az (boring weather here) and fixed some odd things… 3 files updated…
morecellupdates.zip (22.6 KB)
Ok thank you! I will give them a shot!
Hi I am writing from Italy, I followed all your instructions in this discussion to activate my Saratoga weather model on my cell, you can send me explanations of how to insert this cell template in the Saratoga model, where it must be inserted and what I should change why it works
is there an updated model of this cell templete template …?
thank you
Good morning
please can you help me upload the template for android mobile, i have the weather site with saratoga template and i would like to insert your template if you help me,
do you have a guide to do this …?
and the latest updated template …?
thank you
I’m working on updates to this, I will post here and over on WX forums. Sorry i sorta vanished for afew years lol…
Welcome back from the time warp!
Well I wirebrushed all my pages. Add the cool sun dial thing to the front page and got rid of the WU records that didnt work anymore…
Refreshed all the advisories and the radar pages.
I also got the ajax icons to work (as they never did really for some reason if you used “.gifs” before.
Technically the very first status icon shows something slightly different than the ajax version, I can fix that but it requires either copying a bunch of files on top of each other (graphics files) or changing a bunch more code. It has to do with the 1st time the icon is posted and that part of the script which used different icon names and then the ajax script uses slightly different names. If you have jpg this wont be seen I dont believe, this is a gif artifcact.
I can post my source files again if people want them… I will have to compare the files to the standard saratoga package and do a readme again as there is a few files to customize.
As promised, here are my updates… I did a big update to all the pages… They are synced as much as I could to the latest saratoga scripts.
Cell scripts.zip (743.6 KB)
Modified the attachment to fix some errors.
Hello @tman1991, thank you very much for your work. Those of us who don’t know anything about PHP programming are very grateful.
I have read the cellreadme.txt and configured what I could or better known.
I have downloaded the files on my website and the result is quite good, I understand that there are some sections that will not work since some sections are designed for the United States, such as forecast, radar and warnings. I will try to implement something local and what I don’t know, I will remove the menu.
On the main screen practically everything works, but not the Normals / Registers section, which displays zero values.
Regarding air quality information, I understand that airnow does not have information about my location, so I will have to remove it, it is one last thing
Ultraviolet radiation icon indicates low when the value is high
The console says Failed to load resource: The server responded with a status of 404 () rounded.css
I will be very grateful for any suggestions and instructions you want to give me. Thank you very much in advance.
For some reason I didnt get a notification on an reply, sorry for the long response time.
Normal/avg section I got that to work now but its US only as it pulls data from weather.gov. If there is equiv for Spain, we could probably get it to work.
UV I will have to look at why thats not working.
Rounded.css is just a css file that makes pictures round. I will attach it. Also I have refreshed some scripts (again mostly US issues).
Cell scripts 6 jul 2024.zip (768.8 KB)
rounded.txt (1017 Bytes)
Friend, I have nothing to reproach you for your time, on the contrary, I am eternally grateful for your time and your work.
I have customized the script and eliminated some parts that, as you indicate, do not work. I have also worked on translations. I will try what you sent me on a separate server so as not to step on the changes that I have made.
As for the forum notifications, it doesn’t actually notify me when I have responses either. Thank you so much
Go to your forum profile preferences and set Tracking, Emails and Notifications :wink:
It would be possible to display the animated icons of meteo treviglio. Sorry, I haven’t found anything to change this configuration.?
Are you asking to NOT change them or to change to them? I use the animated ones.
Excuse me, I may not have expressed myself well, because I am quite inexperienced. There is a delay, although it is small, as soon as the page loads and the ajaxdashboard web scripts and the icons that cellajaxdashboard loads appear. That’s why I had thought that if they put the same icons, the changes would be less appreciated.
The truth is that I don’t know if I expressed myself well, I’m sorry.
The icon it shows is smaller than on the Saratoga website.
