thanks… why do i need to add another variable?
hmm i dont see the code u are refering too in my cell-ajax-dashboard.php file…
i also found moon errors in this script in what its reporting…
almost thing its better to start with someone elses code and modifiy it to make it work…
it appears the source code i have is old and outdated…
stilling hoping mtn replies with his source code files…
K3JAE
21 December 2011 23:24
202
You cannot use the same variable twice. If you do you will get an already defined error message.
Where exactly do you put the link to the css? There is no head section for this code in the cell_ajax-dashboard.php
-Thanks
each of the 4 files calls out
well at least in my templates … which are terribly old and broken… still trying to get new ones to start from.
Can someone tell me if there is a step by step how to do this iPhone Weather Script.
Thank you
Jean-Robert since you are running the Webster Weather modifications it might be a bit easier for you since there is a template for that…
http://www.websterweatherlive.com/wxScripts.php
MOBILE Dashboard 1.xx Script
Which code are you using? The code from the first page has no calls to css pages in them.
from a zip file i linked a few posts up… but im also working on some newer code… what i have is a mess… it will take me a bit to sort it out…
i have also seen calls to css file in a file called cell_top.php which is in another version i have.
Can you post a link to that zip, I am not seeing one you posted in this thread.
I am using the one from the Original Author from the first post here http://discourse.weather-watch.com/p/341654
But the scripts have no calls to the css page just the css.
ok I have a working cell phone website now… Let me know what u guys think…
One thing I dont have is Air Quality since my city doesnt have RSS feeds go figure… But it has UV/Solar/Fire indexes…
I’m sure the code is not XHTML yet, but I’m going off the templates sets I have… Ill work on that…
Code is based off the many sources and ideas… Hope you like it…
Full website (with lots of custom stuff) http://frogville.us
Cell website Tucson, AZ Weather
Nice work, looks great. This has been something I was working on but didn’t have time to sort through the mess so put it on the side for a bit. Now that their is a working code to use I can revisit it.
You could use this one for AQI…
http://feeds.enviroflash.info/rss/realtime/458.xml
Thanks! yeah ill update my main page with that air quality data and then the cell templates… Ill post back when i have it incorporated… Need to find space on the cell homepage for it…
PS any help on making these XHTML will be good also… Ill do what I can, but a lot of it is beyond my understanding…
If you can zip the code and provide it for download I can clean it up to validate.
sure will do … lemme add the air quality stuff then ill pm u a link for a zip file of my php files…
now added airquality to my version of the cell templates…
Tucson, AZ Weather
MesquiteWx – i emailed you the source to integrate into your error checking versions…
thanks!.. its a combo of a lot of ideas and layouts i’ve seen… I didnt care for the layout of the Webster Weather Live look, so i updated the older templates I found and added a lot of new/newer things to it…
MesquiteWX is going to clean it all up and hopefully publish those templates as a starting point…
Great job tman1991, this is just what I have been looking for.
Did you or MesquiteWX still have plans to publish the templets?
