Mobile / Cellphone / iPhone Browser Script
SAMPLES:
Here’s a screenshot in Opera Mini:
DESCRIPTION:
Is anyone interested in a script for cellphones?
You can have a look here online: [color=blue]Cellphone Weather[/color]
ADDITIONAL SCRIPTS:
Additional scripts you might be interested in:
[color=blue]Cloud Base Graphic[/color]
[color=blue]Gradient Thermometer[/color]
[color=blue]Alternate ajaxWDwx.js[/color]
CREDITS:
Please put the following snippet into your “wxabout.php” page:
Cellphone script courtesy of Bronberg Weather
DOWNLOAD: AVAILABLE SOON
Here’s the source for it so long.
You’ll also need a clientraw.txt parser with it.
- [color=blue]http://www.bashewa.com/cell_ajax-dashboard.php?sce=view[/color]
- [color=blue]http://www.bashewa.com/clientraw-parser.php?sce=view[/color]
Sample page here: [color=blue]http://www.bashewa.com/cell.html?skip=1[/color]
Here’s the source for the forecast page.
You’ll need the updated WU Forecast script for it.
- [color=blue]http://www.bashewa.com/cell-WU-forecast.php?sce=view[/color]
- [color=blue]http://www.bashewa.com/WU-forecast.php?sce=view[/color]
Sample page here: [color=blue]http://www.bashewa.com/cell-forecast.php?skip=1[/color]
You’ll also need the handheld Style Sheet: [color=blue]http://www.bashewa.com/handheld.css[/color]
Here are the graphics required for the cell pages:[[color=blue]http://www.bashewa.com/downloads/bws-icons-current.zip[/color]](http://www.bashewa.com/downloads/bws-icons-current.zip) ..... current conditions icons. [[color=blue]http://www.bashewa.com/downloads/bws-icons-wind.zip[/color]](http://www.bashewa.com/downloads/bws-icons-wind.zip) ........ wind rose icons. [[color=blue]http://www.bashewa.com/downloads/bws-icons-moon.zip[/color]](http://www.bashewa.com/downloads/bws-icons-moon.zip) ........ moon icons x 28 [[color=blue]http://www.bashewa.com/downloads/bws-icons-moonphase.zip[/color]](http://www.bashewa.com/downloads/bws-icons-moonphase.zip) ... moon phase, rising, falling, steady and sun/moon rise & set icons. [[color=blue]http://www.bashewa.com/downloads/bws-icons-forecast.zip[/color]](http://www.bashewa.com/downloads/bws-icons-forecast.zip) .... WU forecast icons.
Thats nice. Would it be possible to add weather warnings/advisories to it?
I’m sure you could.
It’s a stripped down version of the ajax-dashboard.php script.
Looks good will have a play with that after I finish a few of the current projects I have on.
Im getting an error with this line…
$monthname = langtransstr($monthname);
What is langtransstr? is that just to translate lanuages? if so, Can i just make that line to look like this?
$monthname = ($monthname);
Try just commenting it out because $monthname = ($monthname); does nothing.
Yes its for language translation which is done by common.php
Just add these two functions to the bottom of the page:
if (!function_exists(“langtransstr”)) {
function langtransstr($word) {
return $word;
if (!function_exists(“langtrans”)) {
function langtrans($word) {
echo $word;
Make more functions of the same if you run into more problems.
add that to the commom or the cell-ajax file?
Add the functions to the files where you get a problem e.g. cell_ajax-dashboard.php
[http://www.bashewa.com/downloads/bws-icons-current.zip](http://www.bashewa.com/downloads/bws-icons-current.zip) ..... current conditions icons. [http://www.bashewa.com/downloads/bws-icons-wind.zip](http://www.bashewa.com/downloads/bws-icons-wind.zip) ........ wind rose icons. [http://www.bashewa.com/downloads/bws-icons-moon.zip](http://www.bashewa.com/downloads/bws-icons-moon.zip) ........ moon icons x 28 [http://www.bashewa.com/downloads/bws-icons-moonphase.zip](http://www.bashewa.com/downloads/bws-icons-moonphase.zip) ... moon phase, rising, falling, steady and sun/moon rise & set icons. [http://www.bashewa.com/downloads/bws-icons-forecast.zip](http://www.bashewa.com/downloads/bws-icons-forecast.zip) .... WU forecast icons.
I added that to the ajax script and it didnt work. Still getting that same error…
line 241… $monthname = langtransstr($monthname);
Here’s the code for the Gradient Thermometer:
Latest version available here:
http://discourse.weather-watch.com
Sample:
Just replace those function without the “function_exists”:
return $word;
echo $word;
That did it… thanks… now to get everything working on it.
I’ve added the following lines to the cell_ajax-dashboard.php script in case common.php does not exist:
if ((include_once "common.php") == 0) {
return $word;
echo $word;
Get it here: [http://www.bashewa.com/cell_ajax-dashboard.php?sce=view](http://www.bashewa.com/cell_ajax-dashboard.php?sce=view)
