I’ve noticed in my camera file, a camera image is saved only every 10 minutes. Can this be changed to every minute? I would like to import the still images in another software program to make a smooth time lapst movie. Any suggestions?
Darrell
are you using the direct web cam capture or the 3rd party capture?
in the view, web cam image setup, set the web cam image file update freg to 1 minute, and tick update animated web cam image this often
then the web cam image file should get updated every minute (this is like a over ride)
or are you talking about the time stamped image (which is currently every 10 minutes)
if i did a every minute time stamped image, then it would look realy snazy as you moved the mouse over the direction graph…
(i could easily do that for the windspeed/baro graph too…for people who use direction as dots
I’m sorry, I did not explain myself very well. I’m pretty confused with the entire web cam area of the software.
In my web cam folder, .gif are being saved every 10 minutes. Can those be saved every minute? The animated gif is also being saved, but I have not yet been able to figure out how often that is updated. Is one being made every few hours with images that are taken every minute?
Also, I do not necessarly want to UPLOAD a animated gif very often. Just be able to view it and maybe upload it once a day.
When viewing the animated gif, can the speed be changed (frames per second)?
speed: that is possible, but i would have to add that as an option
