Assistance required please
With the CampbellSci loggers, the PC208w software creates a .dat file that WD reads and converts to the log file. It appears that WD reads the last line of the .dat file only. If there is a power outage, the logger keeps logging ok, but when WD is started up, it only reads the last line of data. Is there a way WD can be configured to go back and reread the .dat file at the stage where the power went down?
I am currently using Ver 10.23c with no problems. Keep up the good work
it is possible, but would take a bit of work…as how is wd to know how many lines of data to read?
i.e is the data time stamped, etc?
i guess if the data was new every minute, then wd would know it was missing x number of minutes and use that
then problem is i dont have much time before i head to the UK…
Brian,
Is this problem solved?
I’m sorry - I don’t know. But this is noteworthy in that it must presumably be close to the record for resurrecting an old thread - about 6 years I make it!
Good evening,
(Sorry for my English, it is about a translator)
To date, I with the any problem.
Serge
Serge,
Do you mean that this problem is solved? And that you don’t have any problems?
Good evening,
I have two stations:
A Campbell s
Which version of loggernet do you use?
la CR800.
Serge
Thats the logger himself.
Do you use this software?
http://www.campbellsci.com/loggernet-packages
Yes
Yes
Serge
Do you use only the .DAT file to import in weather display? No .FSL file?
Yes the .DAT
Serge
Is it possible to send me a sample from your DAT file which you use to import in weather display?
what is the particular problem here, or what is the particular change needed, etc?
its not all that clear to me
Brian,
I use a campbell cr1000 logger + loggernet 4.1 software. This software generate’s a DAT file to import in Weather Display.
Now my problem:
How do i now the order/structure of the values? And do i have to start with a time stamp?
