Brian,
On your main screen just above the windspeed dial you have a setting “Solar w/m2” could you please tell me how to get that showing, I have tried everything but to no avail I have just a blank box. #-o
I have the two same boxes above the wind direction dial, % + hrs and below is mm.ET
Many thanks
Geoff
probably will be because you have a WMR200 station
(whereas I have the solar wm/2 coming from a Davis solar sensor)
are you using UV as solar or temperature in a jar as solar, or?
Hi Brian
Yes I have a WMR200 and have a sensor in a jar for the solar, I am getting a nice graph each day, but just the blank box
Geoff
