Boot failure
good afternoon, to see if anyone can help me that I am going crazy, after several power outages the computer that I have the station with the weather display has turned off and now once it starts it does not take all the configuration it had, you know how I can fix it thanks.
hopefully you have back up settings files in the databackup folder where WD is located
copy the wdisplay.ini file from there to where WD is installed (i,e main folder, i.e c:\widsplay )
when WD is not running
FAQ is a wonderful part of the forum: Recovering Weather Display Configuration :smiley:
Luckily after everything I’ve done this was easier, thanks million all restored :raised_hands:t2::raised_hands:t2:
