Last Bohler - WXSIM-Lite Run was ( 2024-05-03-06 z ) and Last Should Be ( 2024-05-03-12 z )
Tom and Sam have been emailed.
Kindest Regards,
Tony
If I recall the emails correctly there was a planned outage today for the FTP data downloads. I no longer use that method so my data wasn’t affected.
Hi Chris,
Sorry not been online, still in recovery after that 4 hr op.
I sent this to Tom/Sam earlier today, so data was on his server just not available for WxSim-Lite. Not had any response as yet.
Hi Tom/Sam/Stuart,
I am still in recovery after a 4 hour Op back on 11th April, though getting better.
I have not spent much time monitoring the automated checks, until just now.
I have found that the Bohler Adv/Data/Lite are all unavailable for WxSim-Lite to import again for run 2024-05-03-12.
Confirmed : When I check :
http://gfs.wxsim.com/lite/mylat/lon
It only returns : 2024-05-03-06
However : When I check : (note: with the date/run suffix)
http://gfs.wxsim.com/lite/mylat/lon/2024050312
It returns the current correct Run, this is same for Adv/data/Lite.
Note : copied in Stuart (FYI) .
Not sure if this is a bug or an expected output, though regardless it seems the data is available on the server, but WxSim-lite is not retrieving it.
Kindest Regards,
Tony
