Bohler - WXSIM-Lite Run 06 z Missing - Last was 2024-04-15-12 z
Last Bohler - WXSIM-Lite Run was ( 2024-04-15-12 z ) and Last Should Be ( 2024-04-16-06 z )
Tom and Sam have been emailed.
Kindest Regards,
Tony
I see that the Bohler data is missing for the same runs as mine which suggests that Sam is using a similar method to me (probably FTP) to download data.
Hi Chris,
Tom and Sam have been auto emailed, though no response.
I have since sent a manual email to them both, again no response.
I had major surgery last Thursday and will be out of action for at least a month. In extreme pain right now, so leaving the auto checks running, I have changed my source to McMahom for now so I do not have to deal with issues. Except for Bohler-Light which I use so that will cause me some issues.
Sorry,
Logging Off,
Kind Regards,
Tony
Hi Tony
Not sure when you’ll see this. Get well quickly. I hope your recovery is much quicker than a month and that the pain starts to lessen very much sooner than that.
I use McMahon and get this message today, 17-4:
Assen
17-4-2024
22:16:01
Data in fdata.txt more than 24 hours old and will not be used in this forecast. You must run WXSIM-Lite to use this mixing routine.
Information: 2024/4/17, standard hour = 21,333, GMT (rounding up hour) = 2024-04-17-21Z, GMT of fdata.txt = 2024-04-15-12Z
17-4-2024
22:18:28
Brgds,
Oebel
Wxsim-Lite is only able to download data from Bohler and the Bohler server is still affected by the NWS storage system problems. I don’t think you can use Wxsim-Lite until Bohler can is able to access GFS data again.
For me it is working again without errors.
Brgds,
Oebel
https://discourse2.weather-watch.com/t/bohler-wxsim-lite-run-2024-04-17-12-z-missing-last-was-2024-04-15-12-z/73574/2?u=administrator says that the Bohler feed is fixed.
