Hope all is well.
I have found this discussion in archives but couldn’t figure anything out.
So here is my wish.
In “Email Warning Setup” Would it be possible to add this option “Use BCC for email list” ?, Like you have it in “Weather Report Email”.
Thanks for all you do.
John
Alternatively, is there a WD file that can be adjusted to force BCC when emailing warnings?
I have warnings sent to 3 emails I control and only show 1 email address so I would say BCC is default in warnings
Thanks for the reply hcorrin,
That’s interesting, I am using the latest version of WD and have 5 email addresses set in my Warnings and all 5 show up on emails that are received.
i am using a mid june 143 build with ssl enabled on both reports and warnings required to use stmp on my email
did you import the emails from reports with BCC checked or just put them in warnings
Darn I thought you were on to something… I just tried importing the emails from reports with BCC checked into warnings email. I still get the same results, all email addresses on received.
I also noticed when i do a test with the switch set to " test mode email to me only" I don’t get the email but with it off everybody gets the test…
