Yoshio
16 September 2011 13:09
1
Hello,
I bought Davis Vantage Vue.
First I did setup several days ago,it is no problem.
But yesterday I did setup for FTTP etc.
So barometer value does not change.
It is same value always.
My setup:
http://starlightcafe.jp/astro/Davissetup.JPG
My image:
http://starlightcafe.jp/astro/Davissetup2.JPG
Barometer is very important for me.
I use it for observatory .
It is very faraway from my home.
Please help me.
But I can not post well this comment this forum maybe.
Yoshio
Is the Vue console showing correct barometer and wind readings?
On the WD station setup you have ticked that you have extra temp sensors…you can untick that unless you actually have extra sensors.
Best to run the latest version of WD, currently 10.37Q build 78.
Yoshio
16 September 2011 14:25
3
Thnaks Norcal,
The Vue console is showing correct carometer and wind direction.
I test in my room,so I understand the corect data.
Today bromater is down,it is low atmospheric pressure arroud my area.
But PC’s data is same barometer value.
My ver is 10.37Q build 02.
I try version up.
Yoshio
Yoshio
16 September 2011 15:11
4
I tryed version up.(10.37Q build 02.)
And I connect to the Vantage Vue.
But the baraometer value is same value.
Yoshio
The latest version is 10.37Q Build 78. Which version are you currently testing?
Do you have a serial or USB weatherlink data logger (interface to the Vue)?
Did you run the weatherlink software before running WD?
What altitude have you set on the console?
windy2
16 September 2011 19:37
6
what do you have set as the barometer offset in WD?
Yoshio
16 September 2011 22:35
7
Hello Windy,
Where do I have set as the barometer offset in WD?
Yoshio
windy2
17 September 2011 00:53
8
control panel, offsets and initial rain
what is the barometer reading on the console?
it will most likely be barometer offset problem, as the screen shot you show, shows a barometer reading of 1066hpa, which is out of range
