WD v1037P Build 44
Davis Vantage Vue using IP data logger plugged into router on 3 PC home network
Windows XP
Just set up WD to receive data with new Davis Vantage Vue. All data is reading correct but barometer is an exception. It is reading much too high, actual pressure is currently 29.77 inches and WD is reading it as 30.01 inches. Is there some setting I have missed. I tried using the Control Panel/Barometer Offset several times but it doesn’t seem to want to accept the correction amount. I did hit the SET button before saving but apparently it will not accept any offset. So the barometer continues to read much too high. Something I missed or is this a true bug with the Davis Vantage Vue IP data logger setup. Thank you for any help.
I have no idea what you mean about not entering any units when entering the offset. A screen shot would be SO useful. I tried setting offset to 0 and hitting Set and saving. It did nothing at all and my barometer reading remains way too high.
OK I went to barometer offset window and typed in -10 in the manual window. Then I hit the Set button. Then I hit the Save button. The barometer reading remain unchanged. It is 10 mb too high. So obviously what you suggested is not the answer.
I installed the latest Wd version over an existing older version. COuld this be the reason I cannot get the barometer offset to work. Is there some internal file I could manually check and change its value? I am anxious to get this working as my station is sending out a barometer reading that is terribly in error on the high side.
I just did what you suggested. It did nothing. Barometer remains way too high by about 10 mb. I am starting to think this is a bug arising from the IP version that has the data logger, in this case a Davis Weather Envoy, feeding data via my router. But since all the other data is being read flawlessly by WD, it has to be something specifically to do with the barometer offset. Can anyone tell me if this sounds logical?
Yes the numbers come up in the box before I hit Set and Save. I used the barometer offset with my previous Lacrosse station for many years. Never had a problem. Soon as I would enter the offset value, the main WD window would show the corrected barometer reading. Apparently it is my switching to the Weatherlink IP that is messing this up. And, as I said before, all the other data is being WD flawlessly every 2 or 3 seconds. Only the barometer reading is way off and needs badly to have an offset correction.
One other thing to check/try – look at the WDSIPLAY.INI file and find the [Barooffsetactual] and see what it is. If it shows 0 then maybe try manually inputting the values here, be sure to save the file before closing. Probably best to do this with WD shut down.
Here is what mine looks like ( I’m not sure what the [Barooffset] number=90 is but it looks like the mb value without the decimal):
[Barooffsetactual]
number=9.0
number usa=0.266 in.
haha…i did not see the date!I make a record!
My station is AERCUS Weathersleuth . I recieve data from wundergound because i do not find settings to grab data from datalogger in live time (if this helps) .
WD is the latest.
I had built 3 and i just download build 4 of the lastest WD . I replace the files in WD directory but the problem not solved (of caurse i restart program). In WU pressure is 1007 and in WD is 1011 . I try again the offset setting and the QFE setting but with no luck .
make sure to use the .zip update of WD from the download page
(and then unzip the updated weatherdisplay.exe to where you have WD installed (exit WD first))
also make sure to not use the QFE setting
