Barometer issue after updating to Vantage pro2
I just updated my weather station from a Davis Weather Monitor II to a Vantage Pro2 and the barometer reading on the vantage pro is not the same as the Weather Display software. The reading on the VantagePro2 is consistent with surrounding readings. Weather Display is .94 in. higher
I may have had some offset with the Monitor II, but it has been many years since I set the software up, I am not sure what I did.
I have looked at the offset tab in Weather Display and just cannot figure out how to use that or clear the data. Instructions are non-existent.
Vantage Pro2 has elevation entered and Weather Display has the same.
Looking for suggestions to correct the issue.
John
The current offset is on the left of the barometer setting and as can be seen in my case is 0 I use a vp2
So if not 0 the in the setting scroll to 0.0 and click on it to get it in the setting box or 0.0 in the set box and tick in box then click set then click ok that should get things working ok
Thanks for the instructions. It worked a after a restart of Weather Display.
John
