Live Updates Error: clientraw.txt file has not been updated for 9 hours, 31 minutes.
We are currently fixing technical difficulties. Live updates will resume soon.
The problem is that 100px is really small, so it will be only a fraction of the original image height. So you should maybe specify which part of the image (vertically) you want to have on the final image.
OK, so I first adjusted the image a little bit - added contrast, corrected the colors, slightly emphasized the sky.
I then chose the middle section for the final banner, but I am also attaching the modified image and if you like some other part of the image better let me know and I can change it. Likewise, Im not sure if you prefer some modern type of font or some old-style font so I made several versions but that can all be changed too.
So have a look and let me know if you want to use one of the attached or make some changes
I like the V1 banner… But could you move the text towards the top and maybe round the corners, or add some type of border around the banner? Sorry for being picky.
Hi, just wondering, did that last version worked? I made the changes based on your last comment, but havent heard from you since then (also in the parallel thread)
Per my other thread in chat, my main pc went down so i haven’t had a chance to try that banner. Once i get my new parts, ill get that banner updated and let you know.
