backup
Hi how do you back up the WD data, I have gone into control panel & clicked on data back up set the switch to on, then clicked back up now, then clicked OK, the page then closes is this right or should I click on arrow, also if I click on test zip fies now, in the compression details box it says zip error missing or empty zipfile ( L/ WD backup/ziptest zip ) also where will the backup be.
many thanks.
Teal
sounds like you need to set the back up directory location correctly
do that via manually running the back up program
Hi, yes I found it its is backing up the data already to my removable spare hard drive, I do not remember setting this up, but I must have done it, so all is well.
many thanks.
teal.
