Averages/Extremes/Reports recreate the web Av/Ext Page "daily.gif"
When you run “view” “Averages/Extremes/Records” “recreate the web Av/ Ext Page”
the resulting daily gif file regenerates the wind directions flat-lined see the attached http://www.docmarvweather.com/20241002.gif
I’ve even tried different builds, starting with build 101 with the same results
By the way, I’m using Windows 10, 16gig ram wd build 152
Check your 102024lg.txt file that the values for wind direction look correct if so run convert logfile to graph then try you recreate again
So I finally emailed Brian about this issue and the newest update seems to be working now,
wdisplay32_b152v10_37s_01292025_1023
thanks for the help Harrold
Brian has released three updates in three days - 28, 29, and 30 Jan. I have the files here: Clayton, NC Weather - WD Archive.
I used to be able to keep track by reading the Version History, but no longer :confused:
A couple days ago the release broke the moviemaker, but its fixed now. This one from yesterday seems to break the 24-graph create and upload.
Jim
After running for a while the 6 and 24 hour graphs healed. It must have been my impatience with the first update after installing todays version.
Jim
Yeah, unfortunately, Brian doesn’t provide a reason for every update in his version history.
I’m not sure what happened but now my computer won’t generate the daily pages or even the month (March2025.htm) files, it was working with the above wd version. Are any of you guys having that issue?
https://www.docmarvweather.com/Daily_Month_detail.html
here’s a screen shot of my settings
Totally confused by the times shown: 00:03, 00:08, 00:09, 00:12, 00:13, 00:18 for a start, then multiple omissions from (presumably) the 5-minute upload intended.
Can only suggest you “Clear All” and start again.
EDIT: and then restart WD
